LC Handlebar dimensions
kurienp
Newbury, Berkshire
Can someone with a more engineering mind than mine help validate the dimensions of the LC handlebar please?
a>
As per my measurements, the dimensions are:
A=900mm
B=150mm
C=40mm
D=140mm
E=80mm
F=280mm
Looking into replacing the handlebar with a Renthal ... but need to ensure that the dimensions are correct first. Looking for one with a reduced sweep.
Ta, :thumb2
K
The BMW handlebar is 32.10mm dia at the clamp area and the Renthal Fatbar (the fattest they have) is 28.6mm :blast:blast ... now to look for a reducer sleeve :blast
Hi pal,
If you find a way to run these bars or find some with less sweep keep us informed as am looking for the same.
Russ
Am also looking for bars with less sweep, did you have any joy finding some?
