Leaking Clutch Hose at Master Cylinder
Squigles
London
OK
Need to replace the rubber 'O' ring on the master cylinder end of the clutch hose. Would replacing this require a bleed of the system or not?
Tom
I would think so, I am sure the system doesn't use normal brake fluid I think it uses Hyspin V10 check first before refilling.
Yes, without a doubt a full bleed of the system is required. Good job it’s the clutch and not the brakes, as that requires the abs pump to be run, whereas the clutch is straight forward.
