Thanks Mart, pics appreciated as I fancy replacing my allegedly super reliable expensive Hid50 setup in the future for something else (had one burner fail previously). Surely more modern LED technology should be more reliable ??
Oh!
Ok now i'm confused to which way the lamp should be facing ??????? i've gone with Up Down like some of the others i've seen but you've gone side to side ??? No idea which is right
HELP!!!!!!
cheers D
So tonight I've bolted on the cheap ass Chinkanese made 18w spot lamps (Need to fit the proper water proof plugs so only temp wiring) but only just finished so had a little ride up and down the road to see what's what so to speak ! The LED H7 lamps are nice and white but no where near as good as my old HID's. I've gone up and down but might try the main on the side to side as looks like it would give more reflection form the lamp ? high beam looks like it's filling the reflector ok. The Spots seem brilliant but again it was more a case of getting them bolted up and need to fiddle with adjustment and tidy wires up. I'll chuck so pick's up in a bit
Cheers D
LED Dipped
LED's dip and high
Dip High plus Spots (all need adjusting properly)
Low beam is still low, ok, i can bring that up no doubt,
My only concern is the LH kick up, it should be the the same distance on the Left of the door as is currently shown on the right.
I know the RH adjuster does Side to side throw, but ive got it almost all the way over to the LH , where do i go if i run out of side to side room ?
Mart
Set the headlight with in a pair of H7 halogens. Then you'll know what the light is expected to do before you fit the LEDs.
Ive always considered my headlight has a flat line dip but I could be mistaken.
Good idea,
I will have a go at the weekend.
means i wont have to jumpstart it as im runing to work lol
But without the aux headlights you may well crash if its dark going to work. The light difference is shocking.
I was being tongue in cheek when I wrote this. I'm not good with emoticons.
The single halogen is adequate but surprisingly weak compared to HID or LED.
I adjusted my bulbs down as far as the adjuster allowed but beam was still slightly too high so I resorted to insulation tape on the headlight protector.
So far not been flashed.
Tried main beam last night, but makes no difference to distant illumination at all.
Sent from my SM-G935F using Tapatalk
