LED Indicator Upgrade
tunnie
Camberley, Surrey.
I have a 2006 GS on 56 plate, I want to replace the front indicators as one is damaged. I thought about a straight swap, but I like the newer LED ones. Brighter and look much more modern compared to my ones.
Done some searching, I think I need this adaptor loom for my bike:
http://www.motorworks.co.uk/vlive/Shop/Parts.php?T=6&Q=LIA11284&x=18&y=19
Then it's just getting the LED indicators?
Is that correct?
Also is OEM still best? Any good alternatives?
Could not find any used on motorworks, how much are these from a dealer? Anyway of getting trade prices?
I just changed the innards on mine to the 2008 led inserts and fitted the later clear lenses,
Mine are damaged, so need replacing anyway.
I want to fit this style:
Ah, I see, I didn't have to do anything with the bikes wiring or fit any resistors when I did my upgrade, don't know if you'll need to with that type sorry
I might do same to my rear cluster as you did to yours, I think the front would benefit from the thinner style. Being 2006 year I think I need the adaptor loom :nenau:nenau:
Is that correct?
Yes, that's the correct adaptor loom kit, which I used on my 57 plate GSA12; may be worth a look on e-bay or here....
http://www.motorcycleparts-hornig.com/BMW-R-1200-GS-Adv-and-HP2/Leds-Lenses-Bulbs/
I went with these as well, and they do look great & super bright...bought a 2nd hand complete set from Motorworks :D
So I would need the adaptor loom for my late 2007 model adventure??
Yes....my mate converted my rear light cluster & all indicators from original to LED on my 57 plate GSA 12 and the adaptor kit is def needed.
It's not a MU.......... it's the 2006 model but I read somewhere that the late 2007 where a bit of a "frankenstein" bike with some of the MU changes!!
(I know...... I'm clutching at straws)
Tapatalked from my MotoX Dev Edition.
Thanks :thumb2:thumb2:thumb2
Do they pop up often on motorworks? I could not see any, unless I'm blind.
Are they LED innards??
Yes, I think they were introduced in 2008 but could be wrong, much brighter than the old bulb ones, plus they look better with the clear lenses in my opinion.
