Sold Lelit Bianca coffee machine V3
Jayjayuno
Bristol England
For budding baristas
Manufactured in 2020 and sold by Bella Barista. 2400 shots.
A very well looked after and maintained prime coffee machine.
Only selling because of an upgrade.
It features
L58E group, paddle system with registered design
Professional water/steam taps with spring closure
LCC with high-resolution OLED graphic display
Lack of water in the tank and "Reserve mode" graphic indicator
Low Flow and Brew Temperature functions
Possibility to activate pre-infusion and stand-by times
Possibility of disabling the steam boiler
Partial and total doses counter
Coffee delivery timer
Temperature displayed in C or F
Double manometer for pump/steam pressure
L58E group manometer for coffee pressure
Water supply and direct discharge
Pump calibration via external adjustment screw
Polished stainless steel appliance body with cup warmer rack and drain tray with wired grate
Walnut wood knobs, lever, paddle and feet
I/O stainless steel back-lit switch
Anti-burn multidirectional steam and hot water wands
Mug friendly
Water tank can be placed on the three sides of the machine
This is a dual boiler with automatic low‑flow mode that mimics manual paddle profiling at the start and end of the shot.
The vacuum breaker and safety valve have been replaced.
This has been descaled recently and regularly back-flushed at required intervals and the lever greased.
Comes with:-
Water Filter,
Valuable extras include 1 blank 2 double 1 single porta-filter
2 brushes
2 WDT tools for improved coffee extraction flow
Stainless steel coffee bean holder to weigh the beans in.
Rubber coffee mat
Bottomless Filter holder,
4 Hole Steam Wand Tip
Tamper
Several baskets including bottomless and blind.
A milk thermometer
I will also include a stainless steel milk jug.
Lelit Manual and Bella Barista manual ( where it was bought from)
It should be noted that I did not use the Lelit water filter but a BWT soft water filter system (consider better by professionals). But the Lelit filter holder is included.
