Les' Ballast Mounting Plate and Oil Cooler Protectors?
I have one of Mark Hooton's covers in front of the cooler. With Les Wassell's plate in behind, that pushes the cooler forward maybe 2mm or so and on mine that was a major hassle to get the cover in front.
It means there is no clearance but so far no probs but it will not go in as per anyone's instructions!
I have the Altrider oil cooler guard fitted with the ballast bracket from Les and all live happily together. The ballast bracket install turned out to be a bigger job than I had thought it would, but it all works great now. If you need some photos; let me know:thumb2
Timmo.
I have got the Touratwat oil cooler guard and Les's plate with four HIDs on it and it works fine.
