Light bar bolt length
Ash
Oh Yes....
Earth
Can anyone tell me the length of Allen bolts needed to fit a light bar to an 1150 GS / A please.
Cheers Ash..
It depends on what light bar and where fitted....
If it’s this light bar (Migsel) fitted under the front beak, then all I can say is mine is held on with 2 M6x40 fillister headed screws. But then I have my light bar packed away from the frame by about 10mm with spacers.
Ian
Cheers Ash..
If no light bar is currently fitted, take one out and measure the length. Then measure the thickness of the light bar you want to fit and add that to the length of your existing bolts, result being the new length you need.
If it's the same as the 1100, don't fit bolts that are too long as you can damage your oil cooler.
