Why dont you just fit a new swith by the speedo, a standard toggle switch will do, also as you may already know, this switch is only effective when the engine is not running. The bike will run in the selected power at start up. You will just need to cut the wire on the plug in module and then extend them to where you will be fitting the switch. I did this , then after a short while i left the bike on full power and done away with the switch. i was forever changing it to low power then full power.
