Likelok + Hexhead
er-minio
London/Rome
Anyone with an Hex using a litelok?
Are you able to use it to lock the bike going through the final drive?
X1 moto that is.
Yes me. No it wont go through, the only place you can get it to fit is around the front tyre/wheel. I’ve spent some time and that is the only real place it can go together with a twat strap around the front brake lever although I’ve still riden off with it fitted 🙄.
Also it’s very easy to carry as I clamp it around the right hand side scaffolding.
It’s a shame it isn’t slightly longer and slightly wider, if it was it would fit loads of places on the bike.
Ah crap.
Considering getting one. I already use an Abus disc lock at the front. I wanted to lock the rear. Going through the final drive is generally would have been optimal.
Thanks for the feedback!
