Lone Rider MotoCAN / Motorcycle Lights | R1250GSA - Settings (Lights Oscillating under throttle load)
Complex_Bird_5528
California, USA
Looking for any feedback / guidance on settings which might be causing Lone Rider Motorcycle Lights to be oscillating under throttle load. Wondering if this is an expected experience or if I need to adjust settings in the MotoCAN.
Thanks in advance!
Thanks in advance!
You need to adjust your settings. Did you plug it in to the correct Ezcan outlet?
I have them on my MY11 TC with no issues
According to Hex, i can only make adjustments / setting changes via the app or wizz wheel
I can adjust all settings except the speed blend via the abs button
I'd be looking at what siddo said,
However i had a hiccip with mine where the upper and lower banks got transposed
pulling the fuse and rebooting the Hexezcan & resyncing the the lights
sorted it all out
You can only get them to work / configure if you use the white outlet if i'm not mistaken
Correct. I thought that too but couldn't remember 100% on how I installed mine.
Thanks in advance!
I'm pretty sure this is modulation, you can confirm by checking the settings in the motolights panel, or covering your dash to make the bike think it's night time. If this behaviour stops when the bike perceives night time, you know it's the modulation feature as it only applies during day time.
Just my 5c on this: if you decide you want modulation but don't want it at high intensity, you can adjust modulation intensity via the circuit's sub-menu.
