Long Shot. Wanted a vertical compressor
Geno
Northern Ireland
I know it’s long shot but would anyone have a vertical compressor or know where I might get one without having to donate a kidney. Something old and on its last legs would suit me , just want it for some spraying use , cleaning paint , blowing dust around. Just asking in case someone has one hiding somewhere. Thank you all for reading.
Geno
not sure why were never popular here. seems to be a common design in lot other countires. great space saving design
i have been on the look out too.
Geno You need to see what CFM your spray gun needs Too small and it will take forever
I have an ancient Compressor with a cast iron Pump and you can stand beside it and have a conversation when running
The other thing you could look into is mounting a standard shaped compressor over the door or under a bench for example
Try to keep it inside rather than a box outside as the chances of condensate build up are much higher in cold weather when its outside
