Sold Looking for a green lane bike (DRZ/XR/WR/TTR...etc)
rustychain
York, North Yorkshire
Afternoon all,
I'm am in the market for a green lane bike. After spending months looking at the cr*p on Facebook I thought I'd try a wanted add on here.
I'm based in York and willing to travel for the right bike.
The bikes I've considered so far are:
  • Suzuki DRZ 400
  • Honda XR 400
  • Yamaha WR 250
  • Yamaha TTR 250
  • Honda CRF 250/300
The list isn't exhaustive, I'm open to other offers/suggestions. Ideally, I'd like something that can be taken on multi day trips without needing a service.
Feel free to private message me if you prefer.
I would think twice about a kick start only bike, i.e. XR400.
Can be a right pain when things play up when you are knackered.
They certainly can!
I have a 2023 plate Husqvarna FE 350 Heritage which I have owned from new. First registered 1st April 23.
It’s done about 30 hours and is in beautiful condition. I’ve only used it for green lanes, not proper enduro.
It’s had three or four oil changes and I always switch over the air filters after each ride as a precaution. I’ve had engine and swing arm covers on from day one to protect the bike.
The mileage/hours are so low because I was also running a Husky 701 alongside the 350.
I’m not desperate to sell but I would for £6750. 👍
I’m based in Bradford, West Yorkshire.
Many folks put a lot of miles on Enduro's, when not raced they do not need as much servicing, just think of road bikes used exclusively on tracks, they go from needing a service every few thousand miles, to every handful of track days - down to hundreds of miles from thousands, its the opposite way around when bimbling about on an Enduro bike.
The bigger the Enduro the harder they are to thrash and less mantenance needed, a lot of folk in the US use 500's as "Dual Sport" bikes and report pistong lasting 20,000 miles, even 350's reportedly manage 500+ hours on a piston - 10,000+ miles, and I just gave my husky 350 a top end overhaul at @150 hours and the piston was in excellent conditon and the bore looked like new (I was always a bit concerned the hours on it when I bought it may not of been genuine - but now think they probably were accurate or fairly close.
You also need to consider if taking a road based trail bike like a DR and then riding it almost exclusively off road you will need to do a lot more maintenance than the manual suggests if you want it to last, so the differnce is a lot less than some people imagine, although obviously a CRF250L will have a longer engine life, it is also bloody heavy (40kg more than an Enduro) underpowered and the suspension needs upgrading, an Enduro will be pretty much fully sorted out of the crate.
Also the "hour meters" only clock up when bike is moving, I often gone for a "long day out" to find I have clocked just 4 hours or so, and it's easy to stretch service intervals to 20 hours for trail riding, giving you 4-5 days riding between a simple (and cheap - they don't hold much) oil change, the 10 hours in the manual assumes you may have spent 10 hours in sloppy welsh bogs at WOT bouncing it off the rev limiter in 2nd the whole time, pootling down a lane at about 1/3rd of that RPM on a whiff of throttle puts a lot less stress on them.
Another consideration is they are deisgned to be maintained regularly, parts are relatively cheap, a full set of genune OE bodywork for my Husky listed at just over £200 inc vat about 5 years ago - side panels, rad shrouds, headlight surround, fork protectors, tail piece the lot - a lot of road bikes will cost that for a single panel.
It just so happens my 350 is for sale, just had a good overhaul and should need nothing for quite some time;
They certainly can!
However that particular day
My bike started up 1st kick, once I was upright & had my footing (thanks Miserable Git) & I didn’t drop it and I was still in the water & I rode it out, no bother
Unlike Phil’s electric start WR250 which refused to start on the button whatsoever and had to be pushed (as Phil is doing in that pic) to dry land and kickstarted by you
Nothing wrong with a kickstart XR400 if
Standard carb
Auto decompressor fully working
Valves checked regularly and spot on
Airbox clean and good filter maintenance is practiced
Mine’s fine, as you know
Afternoon all,
  • Suzuki DRZ 400
  • Honda XR 400
  • Yamaha WR 250
  • Yamaha TTR 250
  • Honda CRF 250/300
Get a KTM EXC or a CRF 250/300 L
You won’t go far wrong with either
I have a KTM 450 EXC, one of the last (legendary!) RFS engined bikes.
I’m the second owner (the first left it in Leisure Trail’s showroom 9 months before collecting it).
Only ever used as a green laner but unused since moving down to Suffolk two years ago.
I have the Beat version and they are great bikes with a kick start as well plus the easy to maintain RFS engine. No shims just the old nut adjustment for the valves so none of the out with the cam business.
I agree with all of the above. I recently asked my local Husky dealer if I should have the valves checked on my 350 as the bike is now approaching 2 years of ownership. You’d possibly expect a dealer to say yes, get it booked in but no, instead they said it won’t need them doing and I’d be wasting my money.
I like that type of bike dealer. 👍
Oldie but goodie don't discount a clean CCM 404e , all the oily and most of the electrical bits of a drz400 but much better frame and suspension
I had one of the 4 race bikes they built a 440DS and recently sold it for the same as what I paid many years ago. Bombproof engine and went on and on with the exception of poor wiring and swinging arm bearings it was a great bike
  • Like
Reactions: GFJ
Thanks for the responses, offers and suggestions which I'll follow up. I'll also do some homework on the suggested alternative bikes.
EXC-F. Don't bother with a CRF-L. You'll only regret it after picking it up for the 10th time somewhere. They are the same wet weight as a 690/701. That's the context you need to put it into.
An alternative is a Beta Alp or Montessa 4 runner. Think 200cc Suzuki engine in a Trails bike chassis with an actual seat. Even lighter than an enduro bike as long as its not the latest model which has been on a seefood diet.
There are guys in our south Wales TRF group who actually use trials bikes and just carry a couple of fuel bottles.
I've used mine on local stuff and its all day long easy as they only weigh 65-70kgs!
I have a WR250R, under 6k miles, if you're interested ;)
I've been considering this, several times.
One of our customers has one. Brings it on our tours, which are approx 2000 miles. Incl Pyrenees, Portugal and soon Morocco. It's good, and will carry some luggage.
I've bought two bikes from 'fin, both I still have. Good bikes
