lost voice prompts.
G5RJO
Middle England
My 590 seems to have stopped giving me voice prompts.... and proximity alerts...
I get music from an internal memory card, no issue, the unit recognises speed cameras and the top banner indicates but there's no verbal warning.
It works out a route but gives no voice prompt at junctions...
Each is set to 100% volume....
Cant get the thing to work.......
It's peeing me off...
Roger.
I take it you have gone into "settings > proximity alerts" and checked these are activated?
You could also try change of voice or a software update?
Or removing the headset from the device and re- pairing it.
Proximity alerts are activated. Software re-installed... same.
Headset is fine.... I'm getting music and a beep if i touch the screen.Just not getting routing and proximity alerts.... strange
Roger
I has something similar (though not on a 590). It was a replacement unit and a little delving around found 'audio system not installed'. only solution was to send it back for a replacement unit.
This wasn't entirely bad news since the replacement came back with 2014 maps rather than the 2011 maps that were on the original.
Suggestions:
1. It's a blessing in disguise not having the thing bleating in your ears; leave it.
2. Back up your device and do a hard reset.
3. Reload the UK voice files or any old voice files to see if that works.
4. Hunt on the www for similar problems.
5. Call Garmin
