Loud rattling then engine stopped...
Steptoe
Him/Bloke/Fella.
S/W London.
Had a non-running bike arrived on a trailer.
Long story short. Owner had a flat battery, jump started bike, left to warm up.
Then it was ridden and a rattling noise appeared.. Got louder and then the bike stopped.
Found a dislodged valve seat which was stopping the valve from sealing when closed. But with no apparent valve or piston damage.
Looks like it from the plug holes and valve sizes.
Maybe left to "warm up" for too long. What do BM recommend? Something like start and ride away immediately?
Run a gauge over the valve, it isn't straight .......
Call BMW, gave them chassis and reg number.... There are two sizes of valve depending on the valve guide length and they can't say which one this bike has, and there are none of any type in the country... The head is at the engineering shop waiting to have new valve seats made, inserted and cut.
Nothing is ever straight forward where BMW's are involved. :D
Germans that haven't recorded every detail of the specification of every bike. Surely not.
You're having a giraffe!
What made the engine stop???? I can see the rattle but not what stopped it, do you think the electronics can detect exhaust fumes in the inlet tract perhaps?
Leaking exhaust valve = poor compression = poor or no combustion. Lambda sees unused oxygen. ECU sees that as excess O2 so turns down the fuel supply. Engine stops
I'm now running a Power Commander. Exhaust pipe headers are grey inside rather than nearly white. Fuel mpg is down only 1mpg and bike is much nicer to use.
I've always used posh petrol as that also reduces exhaust valve temperatures.
