The GSA screen is larger and having riden both, I prefer the GSA screen.So will look for a screen.. are the GSA ones any better than the std GS?.. may be worth getting a used one just to try?...
Hello all I've experienced the same with very low speed stability ie when getting on the train a Folkestone on a GSA and fully loaded we are going to France in July so I am going to try to put a higher pressure in the rear tyre to try to put some more weight on the front tyre
ClassYou're going to put more psi in the rear to try and put some weight on the front tyre ??
Check your head bearings are ok too!
another thread on the waythanks... already checked... but at 12K if they were loose?...
Agree... Screen up to try keep us in a bubble made it dance a bit in cross winds... At 100 Mrs B was getting bashed and wagons made it push sideways. Screen on low worked well for stability at speed, but we were both in the air, turbulence...... So did the flipper thing work well or not much difference? so
And whilst I'm at it.. the front seat after 100 miles... Ouch!
yes.. have some... with silicon bits in... will give them a try... for those longer trips and impressing the ladies![]()
