My 2011 Hexhead has (partially) stripped the lower rear suspension thread. I am fairly sure it is partially stripped as I've discovered that the wrong bolt has been used previously. It looks like the top mount bolt (M10x1.25 x 65mm)
was used instead of the correct bolt - I have been so lucky not to have the bolt come out and collapse the suspension on me.
I now have the correct bolt, but need to run a tap down. The correct bolt being M10x1.5x80mm according to RealOEM. Not being particularly mechanical (basic service skills only), how best should I tackle this? Remove the Swing arm and find someone competent?
Thoughts, comments and observations welcomed.
