Has anyone had the centre stand on a 1200 lowered ?
How is this done ?
How is this done ?
why would you want to lower it?
I crashed my 1200 and now when I put it on the centre stand both wheels touch the ground
Seems to ride ok (now I've fixed the obviously broken bits).
Paul
I hope it's just a damaged centre stand - or you're parking on boggy ground.
Get it looked over, please.
How is this done ?
Cut 50 mm out of both legs of mine, then welded back together. Found that the inside diameter of the legs is such that a 20 mm bolt (head sawn off) is a nice tight fit. I therefore put a bolt in side each leg, just in case (read "for when"!) my welding fails. For the side stand I simply removed 50 mm (vertically - it's more than 50 along the length of the tube) and re-welded the foot back onto the shortened tube. Had both stands powder coated for £15. PM me if you need more details
Take the centre stand off, the bike looks better for it and a paddock stand or wheel chock solves any servicing issues.
