Repoman
Just had my Adv back from a service at Williams in Manchester hoping they would cure the mid range problem I have.
The bike seems to not pull crisply and generally just feels a bit sluggish. Previously I thought this was down to throttle body Balancing (?) as Duffys in Ireland had diagnosed this a couple of years ago and it seemed to fix it, as did a new coil.
Williams diagnosis is that one of the stick(?) coils was badly corroded and that the baffle in the Remus had collapsed, both contributing to the problem.
So advice please:
Is the coil replacement an easy job? I think they quoted about £55 for the part and £25 for the labour so presumably it's a 5 minute job
Why would a corroded coil cause the problem. Isnt it either working or not?
What's the story with the Remus? Can you replace the baffle, if so where do you get one and how do you do it? I was very surprised at this the can doesnt sound any different, just the usual low drone of a thousand bomber raid....
I'm reluctant to give Williams any more dosh as I think £350 for the major service (plus rear pads) was damn steep.
Any diy advice appreciated. Thank you kindly.
So advice please:
