Personally Folks If they Use "Common Sense in the testing of the motorcycles then I would agree
I.E.
Lights work/function correctly Dip to correct side?Check
Tyres Legal and safe?...........................................Check
Brakes working?....................................................Check
Brakes binding or worn?........................................Check
Chain/Sprockets not excessively worn?.................Check
Head Bearings adjusted properly...........................Check
Swingarm bearings Adjusted properly....................Check
Fuel tank carbs assembly sound not leaking...........Check
You get where I am coming from Sound sensible Checks that use real old fashioned common sense!
On the other-hand the ARSEHOLE that came up with a Headlamp alignment check needs a good boot in the Ballix (primarily cos the height stated is always blinding oncoming cars!)
Along with the uneducated twats who test bikes in the northern centres that tell me that a twin cable (push/pull) throttle has to spring back? Eh Hello why has it got a twist to close throttle cable then??
OR the one that Really really Does My Friggin napper in The twat that says that I MUST Have a Dual marked speedo with both sets of digits behind the glass and illuminated
My friend who rides a 125 to and from work was turned down for this! The rest of the little bike being mint!
Sorry for
But As you can see the system will never be perfect whilst some bunch of red tape pushing arses (or should that be Arsii) "thinks" that X needs to equal Y
