Main bulb keeps blowing (1150GS}
rustychain
York, North Yorkshire
Hi. I picked up my GS recently. The high and main beam bulbs were both blown. I fitted some Osram Ultra Life in the hope of getting some longevity.
I've just headed to the garage to tinker and spotted that the main beam bulb has blown in what must be no more than 200 miles. Any thoughts on what might be causing this please? Thanks
Fit new plastic caps & wiring to the back of headlight body
£20 ish from a BMW main dealer
The push on spade terminals should be a FIRM fit and not loose
and the terminals in the plug that plugs into the big round outer cap should be clean and a snug connection not jiggling
Paul is right but with these it's "usually" the spades that jiggle around
I took the bulb out and thought it didn't look blown. I put everything back together and it now works! So it looks like it could be a connection issue. The spades were tight so I'm wondering if it might be the connector which is a little wobbly (but I don't know if they have a bit of play from new)?
PS I was very careful not to touch the bulbs.
