I've been very reluctant to supply batteries until now due to the fact that sealed batteries sit on the shelf until they're required, and wet batteries are a pain in the backside..
This means that a new battery isn't exactly new. It sits in a charged state ready to be fitted to your bike. So it could be many many months old.
But i've now got sealed batteries that are supplied dry. It can sit as long as you like in the same state as it was manufactured, and when it's needed you fill it with the acid cartridge supplied, then seal the battery for life. Simple.
It's a 20amp 12 volt. The maker is an OE supplier to many manufactures, and they are in discussion to supply BMW
It comes with the acid pack and seal. Easy to fill, just insert the acid pack ( non spillable) into the battery and it punctures the pack and the fills the battery. You then push fit the seal and it locks in place.
The cost for a battery is £52- Or £65 fitted.
