just tried cable ties on my old cambridge luggage map holder
it fits really well ..it is easy to get the ignition key in and out
there isno movement or flapping about even at three figure speeds at all!.. although admittedley i have a wider screen fitted ...
no fouling or rubbing of the tank easy access to the petol filler no interference with sterring lock all instruments and warning lights visible .. and as a plus the glasses ?phone case is really handy
just cable tie to the handlebars and then take another tie and
thread it through the one on the handlebars tie to the brake
banjo bolts they cant be seen unless you look from undernieth
the handguards trap the front end to give it stability
i put it on and didnt rate its chances but i really does work
...rock solid 670 mile round trip .. no problems
if like me this has been a problem i hope this helps
