Sold Maypole Strongbox Hitch Lock
DJ123
Berkshire
I believe this is the Maypole Strongbox Hitchlock MP5411 (but cannot confirm), if not, it looks to be the same as this in terms of use & dimensions. It has been lightly used, and otherwise kept in storage box when not in use. I have 1 key for it, and potentially 1 x spare (if i can find it).
Below are the specs from the Maypole website for the MP5411 for this usability of this hitchlock;
Applications for the Strongbox
Hitchlock:ALKO AK270 & AK161AK160A/BAK300A
Steelpress ZSK-1300C/E/H/KZSK-1700B/C/D/EZSK-2000B/CBC-3000.1A/B/C/D
Knott KK14-A/B/CK20-A/B
Suitable for use with most braked and unbraked hitches on drawbars of up to 50mm.Note:
Not suitable for raised hitches, hitches fitted with a skid or those with a delta mounting.
Lightweight and user friendly touring or storage productHigh security lock with anti-drill featureIdeal for caravans and trailers with pressed steel couplings
Fits a straight drawbar rather than an A frame
Helps prevent parking theft when fitted hitched
Strongbox features an anti prising lipIdeal for light trailers
£35 (PPFF) posted to UK shores.
Link to Maypole website
Would it fit this hitch , do you think? If so I'll take it its a hitch on a motolug trailer.
Potentially so - as i think they're still a standard 50mm pressed steel hitch. Although their site doesn't detail the brand.
I'll try and get measurements for you from the gap for the handle>hitch. So you can check if it would fit
I measured the lock this morning;
Distance from end of the lock to start of the hitch gap; 20mm min > 60mm max
Distance from end of lock to start of hitch handle; 83mm > 137mm
Hitch handle hole dimensions; 45mm x 55mm
Sorry for the delay in replying, away in Belgium at moment, se d me bank details and I'll sort payment, thanks.
