Megamoto sat nav
Bengaz
South Shields
Does anyone know if the HP2 MM has an auxilliary socket like the GS had to plud sat nav into.
On the GS its on the headstock area.
Thanks.
Thanks.
Yes, it's on the left hand side (as you sit on the bike), behind the headlamp shell, you can use the same flylead that is available for the GS's. Mine is currently powering my heated grips :D :D
Whilst you're in there - I've also fitted an additional accessory socket into the headlamp shell, with a direct live feed, which I use for my GPS.
Cool np's than Joe.
One more thing I forgot to ask.
Does it have the accessory socket like the GS on the side where I can plug MY BMW optimate thingy jig in?
If not ... its not a problem.
The battery looks fairly easy to get to, just fit the supplied lead direct to the battery then tyrap it out of vision and harms way..
Yes, there's a standard BMW accessory socket on the right hand side near the battery, but as Digga said, it's easy enough to get to the battery terminals anyway.
Here you go :).
Standard fit BMW accessory socket, right side near battery.
My additional socket, right side headlamp shell.
Heated grip switch, left side headlamp shell.
Cool, nice work the elect will be np's for me too.
I like the idea of getting heated grips too.
What kind of handguards do you use?
Are they just a standard BMW order for the MM?
digga, what the heck is that on your nose?
:D Thats not me mate :blast
Why do people think its me ??
Its a bloke that works at our place ... proper 'tosser' size.
He has this 'Sleep Apnea'(spl) thing .... thats the mask he has too sleep in. If he does'nt wear it he partially suffocates, a reflex action kicks in and he wakes up and starts breathing again.
Told him he'd be better off losing 5 stone instead.. :rob
(Apologies to the larger gents out there :comfort)
Mate of mine had the same thing and on handfull of drugs, went on that liquid diet thing and lost 11 stone. Not on a single tablet any more and sleeping disorder gone! It took him months though but he kept with it and said the single most rewarding thing he has ever done for himself :thumb2
Makes me ashamed to think I only need to lose over a stone about and struggle to do that.
