I have had / got this problem. It is particularly noticeable on poor road surface coming out of bumpy bends at speed, hard on the throttle, and can get a bit hairy.
A few weeks back, I set aside some time, took my spanners and screwdrivers out and spent the afternoon riding up and down the same piece of road to try and improve it. The fact that I have a screen fitted makes the problem more noticeable (not worse) as higher speeds are more easily sustained.
I have now managed to greatly reduce the effect, and think it is now as good as it's going to be without a steering damper. I'll know for sure next weekend when I'm in the Alps
For what it's worth, here's my final suspension settings. (I'm 13stones, 182lbs or 83kg depending on when you were born / where you live).
Rear pre-load - factory spec.
Front and rear ride heights at mid distance settings front and rear.
Front rebound damping - 15 clicks out from max
Front comp damping - 16 clicks out from max
Rear rebound damping - 23 clicks out from max
Rear comp damping - 19 clicks out from max
Please bear in mind that the following results were obtained by someone else, riding a different bike on a closed circuit, and that I'm just a bull shitter - officer
Where previously the weave was coming in at 85-90 mph on fast rippled corners, it's now much, much less at speeds up to 115-120 mph Running up as high as 135 mph gives a light feeling at the bars, but nothing that makes you think you want to back off. On one particular stretch where the weave was pretty bad at 95-100 mph I was running through at 120 mph without any issues.
I wouldn't say it's perfect, but now it is bloody good, and I wouldn't really want to be going much quicker anyhow. Backing it down to high 80's and 90's, there are no real issues.
I'm sure a damper would give just a little more confidence running at 3 figure speeds and coming fast of high speed corners, but as it is at the moment, on smooth fast sweepers it's as composed as it's gonna get and at that it's pretty damned good.
Prior to fiddling, I also tried it with the screen on and off to make sure it wasn't just that which was upsetting the handling. I'll decide when i get back from the Alps whether to go for a steering damper or not.
