Are the numbers on the end of the wires If not You're nearly fecked !!!
I used to fit these "things"
Just make sure that the numbers are there or you'll have to do it by pin numba and that aint easy!!!
I may have an old sheet in my old work data folder, if you have no joy?
P.S. Leave out fuel and ignition systems from soldered connections use good connectors so that If it fecks up then you can at least get home by a means other than the 1200's use! Solder all the other connections
