metal mule panniers fitment question
Not good news I'm afraid, these fit BMW panniers but not sure if they changed the dims for later 100pd's
Pannier rack
Lower hook is firmly pressed against the loop
Just move the mounts on the box and shim out the frames with some electrical tape etc. I can't see a problem.
Just what I was about to say. I did exactly that to make MM panniers fit a Holan pannier frame. Dimensions were correct but the pannier brackets were in the way so just a case of moving a couple of brackets over a bit. And ham fisted old me who usually measures once and cuts twice can do it it can’t be that hard.
Just fill any surplus holes with a nut and bolt, or gaffer tape:D
I bought a super thin sheet of aluminium from B@Q , marked and drill holes for the bracket bolts and bonded it to the outside of the bracket side of the pannier. Was perfectly watertight and looked neat.
you know im going to ask for a picture:):):):)
Aaah, that was about 5 bikes ago and they’ve been on another since so the panniers are back to standard now and used to store camping equipment. I’ll see if I can find anything helpful though amongst my thousands of disordered pictures.
