Methyl Hydrate in UK / Europe?
Fireblade
Member
West West Cork, Ireland
In Canada earlier this year, we bought Methyl Hydrate as fuel for the Trangia (as recommended by some Canadian outdoor forum).
It was brilliant! Burnt well, didn’t smell, and left no deposits on the pots. It’s sold there as car windscreen de-icer.
Sadly I had to leave it behind, but in 40ish years of Trangia ownership, I’ve never found anything as good. Does anyone know if/where I can source some this side of the Atlantic?
Methyl hydrate is the same as methanol, also known as methyl alcohol.
Buy it freely in the UK. I guess also in the Republic.
Don’t drink it!
PS Panel wipe is very popular in some circles. Also freely available. Do not confuse it with arse wipe and, most certainly do not use panel wipe as an alternative.
PPS Do not drink panel wipe either.
Don’t drink it!
Is methanol different from methylated spirits? Cos that stinks and leaves your pots all black.
I’ve tried meths (and tried 10% dilution of it), and bio-ethanol - they’re all messy.
Ekofuel is meant to be cleanest.
But none are perfect from memory.
I stopped using the trangia
Fuel, of this sort, is relatively cheap. Experiment as to which you find best in the Trangia stove,
When I was about 10, my grandfather showed me how to make a simple stove from a tin can, sand and neat petrol. Different times. Happy days.
I have been, for years! Methyl hydrate was readily available in Canada, cheaply, and was the best fuel I've ever used.
So far I’ve only found scientific grade methanol at €many/litre.
I’ll keep searching…
I bought some strange stuff for my coleman
Came from an outdoor machinery place , cost me about £40 for 5 litres
reccomended by peeps on here
cant remember its name lol it burns clean though
According to Ai, Bio-ethanol is the better alternative to Methyl Hydrate, for use in a Trangia stove. Produces less soot. Also an alternative to Fossil fuels.
It’s wrong 🤓
I’ve been using bio-ethanol in both my Trangia and the spirit stove on my boat for years, as an alternative to methylated spirit.
The bio-ethanol still gives off an odour while burning, and creates soot.
  • Disslike
Reactions: HxH
It’s wrong 🤓
Nope It's right.
Bioethanol does not produce soot when burned, as it burns with 98% efficiency, resulting in clean emissions of only carbon dioxide and water vapor. If soot is observed, it may be due to impurities in the fuel or improper use of the stove. :teacher As Wessie wrote above.
Perhaps it's your burnt burgers your smelling! :D
I was once told by my mate that Trangia's are best, as i watched him use methylated spirits.
I then explained why i dot think so when he was cleaning more soot than a chimney sweep off his pans.
Ill stick to my small gas cannister lol
  • Like
Reactions: HxH
