Biff
Just Had a letter from Metzeler as follows
As part of METZELER's ongoing quality checks we have identified an issue with one batch of tyres produced in weeks 9 and 10 of 2010 and in line with METZELER's commitment to consumer safety have decided to commence a voluntary safety recall to remove all such affected tyres from the market.
The affected tyres could suffer tread blocks tearing which on some occasions could lead to the separation of some blocks, causing a sudden and unexpected vibration of the motorcycle.
As a precautionary measure METZELER has decided to replace the affected tyres which are only as follows
The tyre size 150/70 R17M/C 69V Tourance rear ,Identifable by the following markings on the sidewall
DOT EB OY B279 0910
OR
DOT EB OY N279 1010
The DOT code can be found on the sidewall
If you have tyres in this size with DOT codes NOT LISTED above then such tyres are NOT part of the recall
Please contact your supplying tyre dealer or contact Metzeler call centre on 08456 094949/07974 153558
DOT EB OY B279 0910
OR
DOT EB OY N279 1010
