Anyone know much about these? I'm looking to get the one that double clicks to toggle, rather than the click and hold. NippyNorman has both however I must be asking the wrong questions.
Here's the situation.
I have 2 pairs of slaved lights. Set 1 is a pair of haolgens slaved to the main beam with a relay that is energised by the main beam feed. These always come on with the main beam. Set 2 is a pair of HIDs slaved to a relay via a toggle switch on the dipped beam feed, therefore I can have the HIDs off while the dipped beam is on.
The first switch (5NB) has an action that requires the cancel indicator button to be pressed for about a second. The second (5NB2) works with a double click on the indicator cancel button which is what I want to control set 2 with.
I can use the long hold output on set 1 if required but set 2 are the only lights I absolutely require to control via the switch and I want to contol them with a double click action.
What I need to know is:-
Does 5NB2 require 5NB to work?
Does 5NB2 have 2 outputs that both need to be fitted?
Many thanks,
David
Many thanks,
David
