Fuzzygs
Have a weird problem. My 2000 GS was running beautifully. Fuel pump was a little noisy though. Went for a ride and a few minutes in, started to cough and backfire running like an absolute bag of nails. Got it home, no start. took the pump out to check the U shaped hose- all seemed good. The wiring on the HES looked crispy so replaced that as the tacho needle was bouncing still no start. Rechecked the timing, pulled the inspection covers from the camshafts and found that the Right cylinder timing chain was loose, the tensioner had collapsed into itself and the spring was missing from inside. Replaced the spring, ensuring the timing was 100% correct and still no start!! Back to basics, spark present, injectors firing still no start. Get the occasional cough like it wants to go but no joy! When I checked the fuel from the pump, it looks like it’s full of air, massively bubbly. Losing patience now
