CHANGELING
Ok I think I read somewhere once that it was a big no no to only change one of your final drive gears ( the big ring gear) regardless of whether you set up the backlash, tooth engagement, shims etc Is this right or can you do it?
I realise the wear patterns will be different on the two gears but surely they will find a happy median before total destruction occurs ? Or am I full of s...t.
but if it is for yourself get a matching gear set or GOOD 2ND HAND FD
