Quote:
Originally Posted by Sunny Jim
Tell me, as a numpty at this depth, is the 'damage' the result of harsh gear changing, lack of oil changing or just good old wear & tear?
The box seems to have been apart a couple of times.
It appears to have had a catastrophic bearing failure which has resulted in the front bearing on the output shaft seizing and spinning on the shaft. Then either the front or rear (or both) output shaft bearings have broken up.
There are teeth marks on the inside of the case near the front of the output shaft and the output drive flange has moved around, distorting the alloy sleeve that surrounds it.
I'd hazard a guess that it ran out of oil in some far distant place and was badly repaired.
The bad repair caused the wear on the selectors and gear pinions.
I don't think harsh gear changes would damage it.
Hopefully its now good for another 100,000 miles .
Bob.
Ah yes - of course
Kenny - don't worry about your flange - it gets slacker with age
