Deleted account 231211001
- Joined
- Oct 8, 2006
- Messages
- 2,106
- Reaction score
- 73
This has got to be the best device I have ever owned!!!! Really, it's that good.
I have 4 bikes all with hydraulic brakes.
With the Mityvac, I have changed the brake fluid in 3 of the bikes in less than one hour!
Take off the lid of the brake fluid reservoir:
Assemble the Mityvac thus: attach the hand pump pistol grip to a short length of tube, conect that to the catch tank, then from the catch tank to the bleed nipple with another, longer length of tube. Squeeze the pistol grip to create a vaccuum, then crack open the bleed nipple!
Keep pumping the pistol grip to keep the vacuum going as long as there's either old pish coloured fluid coming through or there's no more air bubbles, then nip up the bleed nipple. (Keep an eye on the fluid level in the reservoir or you'll be sucking air through in no time!)
Feckin magic and done in seconds without poncing about pumping brake levers and /or pedals.
If you don't buy anything else for your DIY garage kit, buy one of these!
