mono shock mount point removal
pete.keys
Whitchurch, Hampshire
How do you remove the rear shock mount point? This one just won't budge!!
they unscrew but they can be very tight due to corrosion and locktight. heat the housing around the mounting . grip the mount in the vice and turn the bevel drive with some big gloves on.
I used it for extra shock absorber , because the stock was leaking :nenau ...temporary solution until get an ohlins but works amazing well
MOTO GP bikes use the same system - the second tube is air filled as air gives a progressive rising rate, and in the real world steel springs dont
If you beliieve the Ohlins website and anyone who has actually measured them, that is.
