Fanum
Toubab
Anyone know if these pumps are strong enough to sit the tyre bead on the wheel?
Eventually, but it usually takes a lot of faffing with a ratchet strap, whatever soap you have in your kit and a good deal of luck.
Steptoe, I believe some folk strip the outer shell off this model for even smaller pack size, have you done this on your 'bike' version?
But don't forget that the standard 1200 accessory socket will trip out at something just below 5A. These pumps take much more than that.
I understand it runs at 8-9 amps at 12v and has a 15amp fuse. Would this run directly from the battery of my GS1200 do you reckon?
Without a doubt: Yes, it will run fine direct from your bike's battery, via a suitably fused lead, connected by croc clips.
Don't chop what appears to be a cigarette lighter socket plug off. It may contain some sort of voltage regulator. Buy a suitable adaptor from Maplin or somewhere similar.
Job's done.
TWhat I would like to do is remove the croc clips from the Cigarette Socket Adapter and solder the leads to a male Optimate plug so I can just plug into the optimate charge lead!
........ so if I hack off the ciggy plug on the compressor, solder on an optimate plug and shrink wrap....
Steady. It only encourages them.This forum is full of geniuses.....
