Motoscan - How to understand the parameters?
icedfusion
Basingstoke, Hampshire
Having bought a legacy GS-911 many years ago (the yellow one for my K1300R), I decided to get something similar and heard alot of things about the motoscan. However, my one concern is that the GS911 makes it very easy to use but the motoscan just shows you every single parameter you can change with the variables being in German and then some option to change it to - however, how do you know what each of the parameters do and the effect the values will have? You must need some kind of manual, someone must know where this is.
I have a R1250GSA and a K1300S (wanted another K after getting rid or my K1300R).....so any info on the parameters for these two bikes greatly appreciated.
Q1: what is currently wrong with the bike that you need to fix or improve?
Have you gone into settings and changed the user interface language to English?
Take a look at the old mechanic channel on yt.
I want to add LED rear indicators and want this causes LAMPF on my dash (K1300S)
I also want to remove the service reminder so that it never appears on my R1250GSA
I have not, I will take a look! I assumed the parameters are extracted from the modules themselves and use german words (such as hebel=lever, etc), but I will have a look at see if changing the language effects this (the app itself is not in German if that is what you thought I meant).
I will have a look at that, thank you!
