Mounts for auxiliary spot lights
de crowe
west of ireland
What is an alternative to the under beak light bar for mounting some spots Denali D3’s on a 1250 GSA? Any one use fork mounts?
Crash bars is the most common
Have a look at A Bike Thing Youtube channel as he fits them so you will see how he does it on different bikes
Thanks for that, going the SW motec way, although I would have gone with the used Denali's crash bar mounts advertised on this site last week but I was too slow. thanks again
if you havent already pressed the buy button something to consider is does the SW version need to be mounted horizontally? The denali version rotates in two planes allowing them to be mounted on bars at any angle. Hope this makes sense to you
Trigger pulled! thanks all the same
