MRA X SCREEN FITTING.Frm Adventure bike shop
crumbles
C*ntry Bumpkin.
Honiton Debenshire
Having seen a thread on here about the fitting of the screen,spoke to Cliff about them,but then we realised he had not fitted them to a Gs only bike,so one was dispatched to me for evaluation and fitting,next day delivery to (thank's)
On fitting the screen,the Gs screen angle's back at a sharp angle at the edge's,plus round's upward's to.The supplied part's made it possible to fit it square on,although the top rubber clamp ring's appeared to not fit,they do close in enough to grip up to a 100mph on the M/way.
I am 6ft,so i do get alot of wind buffeting and after awhile neckache.
1st
With the long arm's fitted,forget it,the screen shake's and bend's so much it wont be long before the bottom pin,s on the screen will break.
2nd
This time with the screen fitted directly,it is alot better,but you still get the shaky screen but not as bad(extra brace needed i think).This time the wind is virtualy gone,but is replaced with a slight side buffeting which is not to annoying,if i run with the visor up it will rattle it down as the wind force is just over the top of my helmet.
The noise is about the same,i have a C3 which i find noisey anyway and i still have to wear earplug's.
If you want ask anymore question's fire away.
Mike.
http://www.flickr.com/photos/79599274@N03/7155733413/
Should also state,that the screen was bought fairly and squarly by me and this is my own view on this item.
