Multi-Purpose GPS
sven
Haworth, Yorkshire
I've been scratching my head trying to decide which GPS system to buy.
For road use only, I'd probably buy a PDA and Tom Tom software, although I like the idea of a rugged, waterproof solution e.g. Street Pilot III Deluxe (too expensive) or V (memory is too small).
However, as I also like mountain biking and walking, I wondered if I could buy a unit which would be suitable for all three e.g. the new Garmin GPSMAP 60C or the Magellan Meridian Platinum/Colour.
The Garmin is compatible with City Select Europe, although I'm not sure if it autoroutes, and the Magellan needs an additional Mapsend CD (I think) to autoroute (I think), but I'm not sure if it's any good.
Any advice would be appreciated.
Have a look at the e-trex Vista.
With 24MB of map storage it should be big enough.
Also has a "static compass" facility. Which means that you don't have to be moving for it to tell you which direction is north etc..
Altitude, full trip meter, track log with track back etc..etc..
Compatable with any R&R CD, Metro guides, Topo, World map.
It really is versatile. It even has "Jump master" so that you can throw yourself out of a fully functioning aircraft and land where you want. SPLAT! Bugger, forgot the parachute.
Down sides :-
Small screen size, no auto-routing, black & white display.
I have an Ipaq (free from work, glad I didnt have buy it) and I looked at various options for add-on gps to it b4 stumping up for a GPS76Smap , If I was spending the money again I'd look long and hard at the 60CS . The 76S got me round northern spain and covered the route to the ferry using roads and Rec maps, all held in the 24Mb. It doesnt autoroute but u can get round that with planning. The 60CS seems to overcome some of 76s limits, more memory and autorouting. the double memory limit isnt as big a change as would first seem as routing maps use more memory than non-routing. IPAQs and others aren't as motorbike friendly as purpose built GPS units , my IPAQ needs warming up if trying to use screen outside (sub 10 deg C) and dont know how it would feel after 3 hours riding in rain etc.
(donald ducked probably) . A newer handheld may be better but i wouldnt want to guarentee it (ps mine is H3950~ish exact model escapes me at mo).
Iain: The iPaq is not waterproof or dustproof, and would be totally unsuitable for motorcycles.
Sven: My general suggestion to you would be to decide what your primary use will be - handheld or automotive. Once you have determined that, stick within the product category that is primary, and look for a model that offers capabilities for your second purpose. By example, the GPS V is primarily automotive, but is small enough and has long enough battery life for hiking use. On the other hand, many of the newer handheld models provide the ability to load and/or display road data.
PanEuropean
The Magellan will auto route but not with map send. There is new software due out soonish for Europe. Auto routing for the states is out now. I went for the color because I wanted something that could be used on and off the bike and had ample storage. I'm happy with it, but I'm new to GPS and I've only had it a day.
