SMB: I suspect that will be the simplest solution but I want to see if I can get the red DRL's working (0.24 watt) but not have the brake lights work (1.68 watt).
Yes, my indicators arrived last week. Planning to fet them, along with the Innovv K3 next week sometime.
Well I've tried everything but cannot get the running lights working without the brake lights.
I've even "spoke" with Denali in the states. Their T3's won't directly replace the BMW multifunctional indicators because in their wisdom BMW have set the running lights voltage too low at 1.5v whereas most companies set it at 3 to 4 volts.
I'm instead going to fit a pair of Denali T3's wired to the CANsmart.
I had the first of this set up fitted to my now one year old 1250 when it was new. Fitted by the owner and chief tech at a time to suit me. Coffee and cakes supplied and every question I asked was answered without hesitation, much of it way beyond my technical ability. Good people.looks like weiser technik have come up with a solution to give you back your rear centre light on the 21 on models - dont know why the fatherland thought it was a good idea to lose it in the 1st place
REACTIVATE REAR RUNNING LIGHT FUNCTION on 2021-23 model year R1250 GS’s and GSA’s - Weiser Technik
PRODUCT UPDATE This product has been updated to a new plug & play version - MBL-WWIZZRUN R-SEQ V3www.weisertechnik.co.uk
I believe that BM just alter to pd (voltage) of the DRL-low to Brake-high.
The simplest solution that can think of is to monitor the pd of the DRL/Brake light line (grey ?) and adjust the pd to the low value even when the pd is set to high (brake is on). One might have to have a resistor to keep the current draw from the ZFE is as expected when the brake is applied. This should give you a constant DRL even when the brake is applied.
If you have a separate brake light signal ( not part of the rear indicators ?extra brake lights?) I can send you a very simple circuit that will do exactly what you want.
I was just thinking the same.Try connecting them to the front indicator. The front indicator doesn't have a brakelight function. See what happens.
I suppose you don't have multifunctional indicators? Year 22 should have...I was just thinking the same.
I'm now wondering if the front markers will run the rear markers as well, and run the feed to the rears into the centre light for a marker and brake light.
He does not want other indicators.fitting some emblem lights
