Multistrada V4S
I changed the gear lever to the upper position. It is now excellent, really comfortable and easy to use.
And Ducati must’ve changed the brakes because on my 2026 bike they are fantastic.
Quick update. Fitted some AliExpress radiator guards which are excellent and were only £28.
I have also gone for the Evotech lower mount and fitted it last night along with a Garmin power lead. The bike helpfully has an open connector labelled NAV behind the TFT and is working fine.
Not much more required to get the bike as I want it. I need to sort the Datatool system as it doesn’t have a tracker yet. And I’d like a larger screen at some stage, a slip on of some sort too and pannier bags are also on my list. Other than that, all good.
I’m getting used to it now and the handling is sensational. Really glad I bought it.
Which Garmin sat nav power mount did you get?
It is just the cable that connects the nav power outlet to the Garmin cradle. I had to buy a new cradle too as I left mine on the GS. Doh!
So I bought the Evotech bar mount, the Garmin mount and the Garmin cable. The Garmin mount is this one for the XT: Garmin Motorcycle Mounting Bracket, Black/White https://amzn.eu/d/07s1KVxb
And this is the Evotech mount: https://evotech-performance.com/col...mp-sat-nav-mount-ducati-multistrada-v4-s-2025
Thanks for your reply.
It's your power cradle I was interested in where you got it from - I'll need to buy another one.
Those three things give you everything you need for that.
Evo tech rad and engine guards, fogs, sat nav and roadlock
Sent from my SM-F766B using Tapatalk
