It eats front and rear tyres,
Cause it really put me off liking the bike.The UBS connection to the iPod keeps malfunctioning (don't really care)
http://www.ukgser.com/forums/showthread.php?p=3087209#post3087209
There is a new software update to stop this, oh learned one
Take it on a D road, ride at 80mph, drop down to 5th or 4th and accelerate. Then you'll feel the magic![]()
" If I was sliding a bike weighing as much as that does , make no mistake about it, I would be SHITTING myself, followed by getting off it and going for a nice long walk to calm down.![]()
You can feel it slipping and sliding away. Not the usual squirming of a bike under hard acceleration. It won't hold a line through a fast bend, the worn tyre literally being pulled between a part of the tyre that is gripping and a part that is not, made worse as the tyre has to climb over the pronounced ridge between the worn crown and less worn side...You get: Some grip.... climb....fall over the edge (that's where the problem happens, while the bike teeters on the edge of the ridge).... grip.....
The Metzler has a very pronounced 'crown' from new, which means the tyre yaws (left to right to left) really well. But it wears in a very odd fashion, suddenly going from rubber to inner core in quite a short period. I switched the first front and rear set slightly above the minimum legal limit of 1mm left. The second set I thought I would / could take down a bit further.... BIG MISTAKE..... The wear rate accelerates dramatically thereafter....manifesting itself in a bike that is definitely not behaving itself quite as it should.
Rest assured I will not be making that error again.
Put new rubber on it and normal service is resumed..... a pull to the left.![]()
Could someone tell me wether my bike 2011 SE bike would have tyre sensor on the bike.
Also wondering wether to fit my auto com to radio and sat nav or try BMW bt
Which roughly translates as yes, I am indeed the biking equivalent of the Stig
8500 miles so far and loving it. 3x 400 mile days to come riding down to Rome - bring it on!
Fantastic bike!!
Hi all,
Just thought I would let you know a little about my new bike!
If you haven't ridden one, I suggest you just go and have a ride on one, just to see how nice that 6 cylinder engine is.
After my 800 Triumph, which I must admit I have no complaints about if I was riding solo and it had a shaft drive I would have probably kept the Triumph, the 1600 is like the two 800's put together.
It also keeps my wife happy on the back, but you have to keep your eye on your speedo!
Everything the Goldwing has and it just handles like a dream.
I had a 1200RT previously and although it does everything it says 'on the can' I just find it slightly boring to ride, whereas the 1600 although probably not much difference in output, it just feels a totally different bike.
All in all, I am very happy with the bike and attach some pictures for you to see.
They are not the best pics - will get some better ones when the sun comes out!
David
