NAV 6 and or XT invisible?
mw3230
Tyne and Wear
I’m trying to transfer by Bluetooth routes from my XT to a NAV6 but they cannot ’see’ each other. Both devices do see other Bluetooth devices and I regularly share routes with other Garmin satnavs
The NAV6 in question is able to see other devices, including my IPhone but it seems to be blind as far as my XT is concerned
Can anyone suggest a fix or explain why this may be please
Thanks for that. All is well until point 6 when the neither the sending or receiving device lists the other. That’s the issue
Then I’m stumped, I’m afraid.
The only work around would be to put the routes onto an SD card and share them that way, unless you can do something via Garmin Connect?
Thanks I’ll bear that in mind. What I’m also going to try is to Bluetooth to the offending Nav 6 from a friends device which also has the routes
