NAV 6 in a Zumo XT cradle
BDG
Up north
As far I can know the Nav 6 can be used in a standard Garmin Zumo XT cradle. Is this correct or any issues apart from not being able to use the wonder wheel?
Your advice would be appreciated if there's any problems. Thanks.
Have you got this the wrong way around? The XT can be used with an adaptor in a Nav 6 cradle. But I am not aware of an adaptor that allows a Nav 6 to use an XT cradle
No I want to use the Nav 6 on another bike.
Totally different.
And my Zumo 660 works fine in my GSA's Nav6 Mount too......?????
It does but I’m not sure how that helps the OP :blast
My TDK betamax video cassette works brilliantly in my Betamax Video cassette recorder, But, Does it work in my mates VHS video recorder ? I want to use may mates Dyson EU restricted Vacuum cleaner.
Because being polite, it is the only other motorcycle mount that the Nav 5 and 6 actually work in. Although apparently there are some Garmin aviation mounts that may be compatible
Gentlemen, thank you very much for the information, it's very useful. It's the 660 mount I need to buy instead of a zumo XT.
Time for some shopping. Cheers and much appreciated. Thanks Neil.
I have zumo 660 mounts on both my ktm1090 and tdm900 to use a Nav 6 in
Tried the aviation mount it didn’t work for the 660 or nav 5 or 6, I have all three. It’s just a wee bit smaller and the units would not clip in.
