Reading between the lines are you saying I can connect my sena10s to the virb so the virb will record my voice from my sena mic, that would be perfect.
Yes it should do?
You should be able to connect your Sena10 via Bluetooth to the Garmin Virb camera.
When the Garmin is recording video it is also recording your voice (in theory anyways depending on the connectivity of everything)
It sounds like the Bluetooth is having to reestablish connection each time you speak hence the stuttering.Is it set to voice ativated ,see if there are alternate settings that allow continuous recording which will cut out the stuttering?
Looks really smart
I'm going to be starting my install over the next week or so once my camera mounts arrives.
I am no big fan of on-bike cameras, filming, music, telephones and the like but this is a really nicely put together thread and an interesting topic. It shows what can be done with some research and patience. Thank you.
So what was the budget for the total package?
But I'd also heard on the grapevine that these Garmin Virb XE and X models can also connect to OBD2 ELM327 Bluetooth devices.
This means you can connect it to your BMW R1200GS OBD2 Port and suck lots of really juicy data out of the bikes ECU, AS YOU RIDE ALONG.
So I bought this one off Amazon.co.uk last night, which arrived today and I connected it up.
It took about 10 attempts as for some reason the Bluetooth Search on the Garmin Virb XE couldn't find it.
But after repeated attempts it did find it, and it now connects everytime without trouble.
I fitted it to the OBD2 port and put it in a waterproof bag (upside down) to protect it from water ingress.
Where is the obd2 plug located Warlord ?
