Need 1150 Adv pannier check strap photo
Deleted member CB
Spain
Would someone be so kind as to take a photo of the check strap area of an 1150 Adventure pannier, I'm going to fit check straps after breaking hinges on my 2003 ones, I believe panniers after this date came with them. Yes I could work it out, but its a darn sight easier with a photo. :thumb
Hope these Help
Thank you very much Mark, a picture speaks a thousand words!
I've gone & ordered genuine ones & thought I was going to have to drill holes, much clearer now, once again, thanks. :thumb
I have just had one snap!
Not at all happy:rolleyes: first breakage in 3 years of GS ownership:D
New ones are £6.94 from main dealer and they come with new bolts with the rubber washers as well.
You might find when you loosen off the Torx head inside the pannier the bolt on the outside may spin in its housing. I had to jam a screwdriver in the bolt reccess to stop it spinning. No problem with the upper fixing point as it screws into one of the tie down points on the lid.
Jon :beerjug:
