GSAde
Since fitting my Remus Y piece / Revolution / K&N my 1150 GSA Twinspark pulls so much better
(& uses more juice
)I keep thinking I'm only in fifth when I've already cogged up to top. Was wondering what she'd be like with the O/D box from a std 1150.
When I got the GSA (after two std 1150's) I thought the lower top was a much more usefull ratio most of the time but now feel it would probably pull the overdrive OK - which was nicer on long runs & when touring abroad. As I never fitted the above kit to my std 1150's I don't know how well they pull the O/D top so can't answer my own question, so to speak.
So question is I suppose
Firstly can you fit an 1150 o/d top gear to the GSA or would it have to be the complete box (££££
For owners of std 1150's with the above setup how well did they pull (subjective I know) when you did the mods - I certainly felt o/d top was a bit overgeared with the standard setup.
Thanks in anticipation
Ade
(& uses more juice When I got the GSA (after two std 1150's) I thought the lower top was a much more usefull ratio most of the time but now feel it would probably pull the overdrive OK - which was nicer on long runs & when touring abroad. As I never fitted the above kit to my std 1150's I don't know how well they pull the O/D top so can't answer my own question, so to speak.
Ade
