Need to source an 'arse about face' Brake light switch
Wreford Miles
West Dorset on the TET/GWT
My HP2 has a non standard front brake with a hydraulic switch which operates in a way that I expect many do - When the brake is applied the switch closes the circuit and the brake light works.
The original BMW (HP2 Mega Moto) switch it appears worked the other way around - it opens when the brake was applied
Q: Does anyone know where I could get a hydraulic switch which works in this way?
Wreford
If you can't get a switch you could add a relay with a set of normally closed contact.
I was trying to think that one through but my head was hurting:nenau
So the current swith would close which would cause a relay to open, so if the brake light connections where connected to the relay they would think the brake was on...
Would the relay not need a power feed?
I'm drawing a blank on finding a switch that breaks the connection ratner than makes it when the brake is applied so I may have to look at the relay route
Any views on how to do this or other options?
Wreford
Wreford
Is it not just a matter of wiring a conventional switch 'backwards' so the open position creates the circuit rather than breaking it? :confused:
I dont think so as the switch only has one action to close a normally open connection or open a normally closed connection.
Hydraulic ones seem to close a 'normally open' switch
Something like this (assuming the switch closes the positive - check with meter, if not just reverse polarity of the diagram)
Would need to be a two way switch with both a normally open and a normally closed connection. Unlikely to be fitted, but definitely worth checking.
You need a 5 pin relay,
You use the hydraulic switch you have to operate the relay, so power to the hydraulic switch, power from the switch to the relay, you then wire the original switch circuit to the relay using the extra pin 87A rather than the 87 pin the energised relay then turns off the power to the original circuit.:thumb
That make sense so the power is all on the brake lever side of the relay and the relay just closes an open connection on the command of the brake switch closing a normally open connection.
A lot of friggin wire to solve a problem but unless I can fined a normally closed hydraulic switch I'm a bit stuck
Ah yes - saw Rudie had gone with the relay, thought that was it, but you were OP.
Well, search "hydraulic pressure switch" rather than specifically "brake switch" and normally closed (N/C) is what you need.
Good luck!
Ian
I'm now thinking relay is the best option
5 pin relay
Connect brake light lead that is NC to 30 and 87a
Wire one side of the in place hydraulic switch which is NO to a power feed (not sure which power feed is best)
Then and connect to 85
Then connect 86 to the bike for an earth
In theory I apply the front brake which closes the NO hydraulic switch, which then triggers the internal solenoid to make a connection between 30 and 87 and in the process breaking the connection between 30 and 87a meaning the brake light comes on
If I'm right my challenge is where do I take the power from and how should I earth it.
Need a plan B as the thread is not long enough or designed to work in a banjo.
Plan B might include:
Finding a banjo with two connections and have one with a short feed going to this switch
Sorry, I wasn't aware of the required thread. Anything here to help? http://www.earls.co.uk/earls/adapters/brakesystemadapters.html
Or these are cheap & common:
http://www.wemoto.com/parts/picture/hl-171020_5/
Replace the bleed nipple with your switch.
Mucking about with relays seems over-complex (more wires, connections & switches to go wrong). :blast
Failing all that, find a friendly machinist to make an adaptor. :nenau
Thanks Ian,
I did call Earls for a switch ( they only had NO) but the adaptor route looks very promising
