New bbq food smoker
john_aero
Glin, Ireland
Just a wash and assebmly and will have my new ugly drum smoker ready
Show us the interior?
Why did you go for vertical rather than horizontal? Lower temperatures at the top?
Start a proper thread on the Food and drink section?
Al
Didnt know was food thread
Lik vertical for simplicity and and less work
Add water pan and control temp easily
Le GSTro.......... A section on its own
For all the "foodies"
Al
got all the bits last week,
new drum, grills and stainless hardware
chopped up old frying pan to use as a water pan
picked up cheap bbq from argos from argos for 13e and used bottom of bbq for ash pan and cook grill as base for charcoal basket
had 2 burn outs to clean drum
grinder to make sure all fully cheap at bottom of them barrel here paint didnt fully burn off
then marked and drilled it up
3 racks, 2 for cooking and 1 to hold water pan or heat diffuser
bottom sliding vent and chimney on top with adj damper
couldnt find my metal hole saws so chimney holes is not very circular
but all left is weld on chimney on, wash it out and season
not had time today so hope head to fatherinlaw wednesday to use his welder
hope get cooking at weekend
got good use out of oven last year
need finish it off and insulate it btu works great
Have a similar smoker but the smoke temp was too high and ruined a few salmon... I know run the smoke from a separate source through an aluminum pipe to cool it down.
Have the material bought for pizza oven too, just gotta build it. You've a very nice setup
I suppose depends on seals on drum. Too hot temp means coals too hot so dampers opeb too much
But do know most woulnt smoke fish on them as they best done with a cold snoker not hot smoker
But i do knoe takes good few goes to learn catch temp on way up theb hold it
I plan just throw some cheap oily snd fatty meat on to run it to learn its ideal setup and season it
Oven was food fun build
If was re do it id takr more time at top dome instead rushing to finish it as looks a mess inside
But hey it works and if anyone wants stick head in to check st full temp go ahead
Just heads up, breeze blockd are great base indulation and 10mins to lay plus cheap
No need mix vermacrete for base insul
Brian
I am looking building commercial one so if knoe anyone with small farmets milk trailer let me know
Has been mentioned about a pizza run
Nice job that man.
I bought a smoking cabinet a few years ago and thoroughly enjoy the use of it.
I use the ProQ Cold Smoke Generator to make smoke. It works a treat.
I smoke; trout, salmon, haddock, cheese, boiled eggs, chillis, garlic, meat...
